03-21-2014 07:07 AM
I'm trying to deploy the AIO demo to the myrio, and everytime I press search project in the Run Configurations dialog, no binaries appear. Can someone please help me! This is apart of my TSA Engineering Design event entry, and it's due tomorrow. And yes... I did build the project first.
03-21-2014 09:50 AM
Hey jeremiahb,
It sounds like you are trying to build and deploy a startup exe to run on the myRIO, is that correct? If so here is some information on doing that.
Is the project you're trying to deploy a built in sample project or something you (or someone else) built? Where is the Run Configuration window you referred to?
Thanks!
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
03-21-2014 10:25 AM
I am attempting to deploy the AIO C# example onto the myRIO.
03-21-2014 10:56 AM
Hey jeremiahb,
Did you go through the instructions here? Let me know if if those don't help I'll set this up here to try and help out.
Thanks!
-Sam K
03-21-2014 11:05 AM
Yes, I have followed all of these steps. I'm getting the following errors when building:
Description Resource Path Location Type
Symbol 'SYSAO_SCALERDY' could not be resolved main.c /myRIO Example - AIO line 77 Semantic Error
Symbol 'SYSAI_SCALERDY' could not be resolved main.c /myRIO Example - AIO line 76 Semantic Error
Program "gcc" not found in PATH Preferences, C++/Build/Settings/Discovery, [CDT GCC Builtin Compiler Settings] options C/C++ Scanner Discovery Problem
Symbol 'uint16_t' could not be resolved AIO.c /myRIO Example - AIO line 80 Semantic Error
Program "g++" not found in PATH Preferences, C++/Build/Settings/Discovery, [CDT GCC Builtin Compiler Settings] options C/C++ Scanner Discovery Problem
Type 'uint16_t' could not be resolved AIO.c /myRIO Example - AIO line 57 Semantic Error
Type 'uint16_t' could not be resolved AIO.c /myRIO Example - AIO line 87 Semantic Error
Symbol 'int16_t' could not be resolved AIO.c /myRIO Example - AIO line 80 Semantic Error
Type 'int16_t' could not be resolved AIO.c /myRIO Example - AIO line 159 Semantic Error
Type 'uint16_t' could not be resolved AIO.c /myRIO Example - AIO line 133 Semantic Error
Symbol 'AIA_3WGHT' could not be resolved main.c /myRIO Example - AIO line 65 Semantic Error
Symbol 'AIA_3VAL' could not be resolved main.c /myRIO Example - AIO line 64 Semantic Error
Symbol 'AOB_0VAL' could not be resolved main.c /myRIO Example - AIO line 69 Semantic Error
Symbol 'AIA_3OFST' could not be resolved main.c /myRIO Example - AIO line 66 Semantic Error
Symbol 'AOB_0OFST' could not be resolved main.c /myRIO Example - AIO line 71 Semantic Error
Program "gcc" not found in PATH myRIO Example - AIO [Discovery Options] page in project properties C/C++ Problem
Program "make" not found in PATH myRIO Example - AIO C/C++ Problem
Symbol 'AOB_0WGHT' could not be resolved main.c /myRIO Example - AIO line 70 Semantic Error
Symbol 'SYSAIRDY' could not be resolved main.c /myRIO Example - AIO line 75 Semantic Error
Symbol 'AOSYSGO' could not be resolved main.c /myRIO Example - AIO line 72 Semantic Error
Type 'uint32_t' could not be resolved AIO.h /myRIO Example - AIO line 44 Semantic Error
Type 'uint32_t' could not be resolved AIO.h /myRIO Example - AIO line 43 Semantic Error
Type 'uint32_t' could not be resolved AIO.h /myRIO Example - AIO line 42 Semantic Error
Type 'time_t' could not be resolved main.c /myRIO Example - AIO line 50 Semantic Error
Type 'uint32_t' could not be resolved AIO.h /myRIO Example - AIO line 29 Semantic Error
Symbol 'AIA_0WGHT' could not be resolved main.c /myRIO Example - AIO line 60 Semantic Error
Type 'uint32_t' could not be resolved AIO.h /myRIO Example - AIO line 30 Semantic Error
Symbol 'AIA_0OFST' could not be resolved main.c /myRIO Example - AIO line 61 Semantic Error
Type 'uint32_t' could not be resolved AIO.h /myRIO Example - AIO line 27 Semantic Error
Type 'time_t' could not be resolved main.c /myRIO Example - AIO line 51 Semantic Error
Type 'uint32_t' could not be resolved AIO.h /myRIO Example - AIO line 28 Semantic Error
Symbol 'AIA_0VAL' could not be resolved main.c /myRIO Example - AIO line 59 Semantic Error
Type 'uint32_t' could not be resolved AIO.c /myRIO Example - AIO line 186 Semantic Error
Type 'uint32_t' could not be resolved AIO.c /myRIO Example - AIO line 187 Semantic Error
03-21-2014 11:51 AM
From that it sounds like your path variables are not setup correctly. I'd run through the Setting up 'Software Environment' section of that document again to make sure all the paths are correct.
-Sam K
04-29-2014 04:00 AM
I've been through that section multiple times. Even on my new laptop, and it still does not work. The project just won't build. I've done everything correctly.
Description Resource Path Location Type Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - PWM [Discovery Options] page in project properties C/C++ Problem Type 'uint32_t' could not be resolved DIO.h /myRIO Example - DIO line 24 Semantic Error Type 'NiFpga_Bool' could not be resolved DIO.h /myRIO Example - DIO line 34 Semantic Error Type 'uint8_t' could not be resolved DIO.h /myRIO Example - DIO line 27 Semantic Error Type 'uint32_t' could not be resolved DIO.h /myRIO Example - DIO line 26 Semantic Error Type 'uint32_t' could not be resolved DIO.h /myRIO Example - DIO line 25 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 58 Semantic Error Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - Encoder [Discovery Options] page in project properties C/C++ Problem Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - Accelerometer [Discovery Options] page in project properties C/C++ Problem Type 'NiFpga_Status' could not be resolved DIO.c /myRIO Example - DIO line 57 Semantic Error Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - AIO [Discovery Options] page in project properties C/C++ Problem Type 'NiFpga_Bool' could not be resolved DIO.c /myRIO Example - DIO line 55 Semantic Error Type 'NiFpga_Session' could not be resolved DIO.c /myRIO Example - DIO line 27 Semantic Error Type 'NiFpga_Bool' could not be resolved DIO.h /myRIO Example - DIO line 40 Semantic Error Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - DIO [Discovery Options] page in project properties C/C++ Problem Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 161 Semantic Error Symbol 'DIOA_70IN' could not be resolved main.c /myRIO Example - DIO line 66 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 162 Semantic Error Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - SPI [Discovery Options] page in project properties C/C++ Problem Symbol 'DIOB_70DIR' could not be resolved main.c /myRIO Example - DIO line 69 Semantic Error Symbol 'DIOB_70OUT' could not be resolved main.c /myRIO Example - DIO line 70 Semantic Error Symbol 'NiFpga_False' could not be resolved DIO.c /myRIO Example - DIO line 178 Semantic Error Symbol 'DIOB_70IN' could not be resolved main.c /myRIO Example - DIO line 71 Semantic Error Symbol 'NiFpga_False' could not be resolved DIO.c /myRIO Example - DIO line 215 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 59 Semantic Error Symbol 'DIOA_70OUT' could not be resolved main.c /myRIO Example - DIO line 60 Semantic Error Symbol 'DIOA_70IN' could not be resolved main.c /myRIO Example - DIO line 61 Semantic Error Type 'NiFpga_Bool' could not be resolved DIO.c /myRIO Example - DIO line 157 Semantic Error Type 'NiFpga_Status' could not be resolved DIO.c /myRIO Example - DIO line 159 Semantic Error Symbol 'DIOA_70DIR' could not be resolved main.c /myRIO Example - DIO line 64 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 160 Semantic Error Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - I2C [Discovery Options] page in project properties C/C++ Problem Symbol 'DIOA_70OUT' could not be resolved main.c /myRIO Example - DIO line 65 Semantic Error Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Example - UART [Discovery Options] page in project properties C/C++ Problem Symbol 'NiFpga_True' could not be resolved DIO.c /myRIO Example - DIO line 226 Semantic Error Symbol 'NiFpga_False' could not be resolved DIO.c /myRIO Example - DIO line 226 Semantic Error Type 'time_t' could not be resolved main.c /myRIO Example - DIO line 50 Semantic Error Symbol 'DIOA_70DIR' could not be resolved main.c /myRIO Example - DIO line 59 Semantic Error Type 'time_t' could not be resolved main.c /myRIO Example - DIO line 51 Semantic Error Program "arm-none-linux-gnueabi-gcc" not found in PATH myRIO Template [Discovery Options] page in project properties C/C++ Problem
04-29-2014 04:26 PM
Hi jeremiahb,
If you navigate to:
C:\Program Files (x86)\National Instruments\Eclipse\toolchain\
gcc-4.4-arm\i386\bin
Can you verify that the files are located there? What does that directory look like?
Also, can you assert that you are using Windows 64 bit?
Let me know how this goes,
Nick
04-30-2014 12:45 AM
04-30-2014 01:50 PM
Hi jeremiahb,
I do see that all of these files are located at the directory that you have shown, but this is not the same directory that your "PATH" variable is set to. In your earlier photo, it appears that PATH is set to C:\Program Files\National Instr... where the directory in your last image is C:\Program Files (x86)\National Instr...
Try changing your Environment Variable "PATH" to reference the x86 version of the Program Files. This should allow the software to find the directories.
Let me know how this works!
Nick
