05-01-2014 08:02 AM
Thanks!! It was able to build and produce a binary, but there's still alot of semantic errors?
Description Resource Path Location Type Symbol 'DIOB_70DIR' could not be resolved main.c /myRIO Example - DIO line 69 Semantic Error Symbol 'DIOB_70OUT' could not be resolved main.c /myRIO Example - DIO line 70 Semantic Error Symbol 'DIOB_70IN' could not be resolved main.c /myRIO Example - DIO line 71 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 162 Semantic Error Symbol 'DIOA_70IN' could not be resolved main.c /myRIO Example - DIO line 61 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 161 Semantic Error Symbol 'DIOA_70DIR' could not be resolved main.c /myRIO Example - DIO line 64 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 160 Semantic Error Symbol 'DIOA_70OUT' could not be resolved main.c /myRIO Example - DIO line 65 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 59 Semantic Error Symbol 'DIOA_70IN' could not be resolved main.c /myRIO Example - DIO line 66 Semantic Error Type 'uint8_t' could not be resolved DIO.c /myRIO Example - DIO line 58 Semantic Error Type 'time_t' could not be resolved main.c /myRIO Example - DIO line 50 Semantic Error Type 'time_t' could not be resolved main.c /myRIO Example - DIO line 51 Semantic Error Symbol 'DIOA_70DIR' could not be resolved main.c /myRIO Example - DIO line 59 Semantic Error Symbol 'DIOA_70OUT' could not be resolved main.c /myRIO Example - DIO line 60 Semantic Error Type 'uint32_t' could not be resolved DIO.h /myRIO Example - DIO line 25 Semantic Error Type 'uint32_t' could not be resolved DIO.h /myRIO Example - DIO line 26 Semantic Error Type 'uint8_t' could not be resolved DIO.h /myRIO Example - DIO line 27 Semantic Error Type 'uint32_t' could not be resolved DIO.h /myRIO Example - DIO line 24 Semantic Error
05-01-2014 08:04 AM - edited 05-01-2014 08:05 AM
[DELETED]
05-02-2014 08:45 AM
Hi jeremiahb,
It appears that some of the variables as well as data types are not being imported correctly. Can you assert that you have included all header files required to execute this example?
Also, you mentioned that you were still able to produce a bit file. Does this file function as expected? What kind of behavior are you seeing?
Nick
