my problem is when i connect NI MyRIO to my computer, all the 3D object disappear from the palette(3D picture,3 axis..).I tried to copy and paste an example of vi that contains a 3D picture but i always get errors saying type not supported in current target or wire not supported in current target. What can I do to solve this problem?
When you check this VI in your project explorer, is it under your target instead of "My computer"?
If the answer is yes, this means your are editing a real time VI, and those functions are not present in the palette since they are not supported for real time targets. If you want to use them, you can transfer the information from the Real Time VI to a host VI (running in your PC).
