I want to move my 3 axes machine as a 3D printer using STL file. But it only gives me the vertex points. how can i get the list of positions in which way my machine will move?
So, from vertex points how can i get the coordinates of the position??
What is the part of your problem related to LabVIEW? Did you generate the .stl file using LabVIEW or do you control your 3D printer using LabVIEW? You'll have to be more specific with your question.
