Digital I/O
How to connect the digital output sensor with NI WSN 3202 Analog Input Node using I2C protocol
Hi everyone,
How to connect the digital output sensor with NI WSN 3202 Analog Input Node using I2C protocol.
Reply ASAP
(5,684 Views)
That cannot be done, since 3202 DIO is not fast enough. Consider using 3230 RS-232 node with 232-T2C converter.
(5,681 Views)
Hi Kate,
1. Actually my aim is to connect sensor which gives digital output with My NI WSN Node (we have 3202, 3212, 3226 nodes).Here,
Sensors( Total 4)  are mounted on a PCB which have I2C pins to interface with the node so how should i proceed to get the data.
2.Do we have access to connect the sensor which gives digital output with our Nodes or not?
                                                  Thanking you
Warm Regards,
Abhinav Sharma
(5,678 Views)
Hi KateB,
I just wanted to know that for
1.what purpose DIO is used for which is provided on the Node (3202,3212,3226).
2.What type of sensors do we require to connect with DIO.
3.All the sensors which give digital output requires I2C or SPI interface to communicate. so for that we need to go with NI 3230 RS-232 Node.
Reply as soon as possible.
Warm Regards,
Abhinav
(5,653 Views)
