Out of Memory XML Report Problem
Hi:
I'm using XML Report option with the expand.xsl StyleSheet in my Testand 3.5.
Sometimes I got the Run Time Error : 'Out Of Memory' ( Attached jpeg which shoes the error).
Can somebody tell me what can cause the error? Now I have 1Giga Ram in my PC.
Ofer
Message 1 of 9
(5,343 Views)
Hi Ofer,
Are you using "On-The-Fly Reporting," or "Append if File Already Exists" in the Report Options?  This may be a source of the error that your are seeing.
NickB
Message 2 of 9
(5,307 Views)
The answer is No for both questiions. Again: the problem does not occur every time. I also think that it occurs only if report file is very large.
Ofer
Message 3 of 9
(5,300 Views)
This appears to be a problem appears to be a limitation when passing a very large string to COM.  The size of your RAM will not affect this, as we can only get a contiguous block of memory so large when calling the COM object creating the report.  The XML report by its nature is extremely large.  If you do not need the data in an XML format, one option is to switch to the HTML report.  The size of the report will be considerably smaller.  If you prefer an XML format, you may want to switch to using the ATML format (if you are using TestStand 3.5 or higher).  This format will be smaller but still provide an XML format to read.  If neither of these options are acceptable, let me know so we can try to figure out an alternative solution for you.
Allen P.
NI
Message 4 of 9
(5,283 Views)
Hi Allen:
Indeed, My xml reports are very large. It can reach to 80Mb. The reason I'm using xml is because of its expandable feature.
The stylesheet I'm using is: expand.xsl.
Does ATML format has this feature?
Ofer
Message 5 of 9
(5,245 Views)
Unfortunately there is no expand style sheet for the ATML report.  Since the XML report is too large, you will have to give up the expand style sheet and choose one of the alternative report formats.
Allen P.
NI
Message 6 of 9
(5,236 Views)
Ok,
I'il choose the HTML format.
thanks,
ofer
Message 7 of 9
(5,220 Views)
I wonder if there is a way to programmatically change the format based on the sequence we run?  One sequence we run generates lots of results, runs > 24hrs, while another is much shorter.  I'd prefer the xml format in the latter.
David J.
Message 8 of 9
(4,328 Views)
You can override the ReportOptions model callback in your sequence file and change Parameters.ReportOptions.Format to xml.
-Doug
Message 9 of 9
(4,317 Views)
