Memory clearing of Ethernet GPIB Controller
I use a 778209 controller on a classified standalone test system for a government contract. The DoD requires that I identify the size & type of media (electronic memeory in this case) and either identify contents of the media or establish a method to sanitize the media.
Here is an example of the sort of media information I am required to provide (which seems not to be available from any NI manual I can locate)
Size & Type
 SDRAM 512 MB /
EEPROM 32 KB /
CPU FLASH 512 KB
Sanitization
SDRAM Power down for at least 30 seconds to sanitize (erase).
EEPROM – Contains unclassified instrument operating
data: not user accessible. CPU FLASH – Contains unclassified
BIOS.
(2,716 Views)
Hello MattJ,
The following two KnowledgeBase entries from the Support area of our website should answer your questions:
Memory Buffer of GPIB Interfaces and Letter of Volatility
What Does My ENET Device Store After the Power Is Turned Off?
Let us know if there is more information that you need!
Jason S.
Applications Engineer
(2,705 Views)
