11-28-2007 10:34 AM
11-28-2007 09:51 PM
11-29-2007 05:35 PM
06-02-2008 11:53 PM
06-03-2008 08:29 AM
06-08-2008 10:45 PM
06-08-2008 10:52 PM
10-12-2008 12:10 AM
maybe somenone can tell me all about this:
1. what frequency must we have to analyse the ecg signal
2. what filter must we use to make a good ecg signal
3. what is the frequency cut-off of the filter in there if we use them (low and high frequency cut-off)
4. how to save the result of ecg signal to JPEG or files or cordinate system
10-12-2008 04:10 PM
There is a lot of information on NI's and the web on ECG acquisition and analysis. One is this. Try doing a sarch for ECG. There is also the Biomedical Toolkit. It uses NI data acquisition hardware but can be modified for your DAQ device.
10-13-2008 02:19 AM
Dear Marp84,
Last few months,I was doing my project related to the ecg signal. I try my best to help you regarding to the ECG signal processing. It is important for you to know what is the ECG signal and how to deal with it. The ECG is the electrical recording and being used to investigate heart disease. The most important characteristic of the ECG signal is the QRS interval. This 3 characteristics can be used to determine the heart rate and other further diagnose.
Here are the possible solution for your questions.
1. what frequency must we have to analyze the ecg signal?
When I was doing my project,normally I use less than 1K hertz to acquire the signal from the ECG device. If I increased the sampling rate, the QRS structure cannot be seen/extracted from the device. So it is hard to detect the QRS point from the acquired signal. Furthermore when the sampling rate is high, we cannot have the correct waveform for the ECG signal. so it is better to put lower sampling rate and increased the number of sample. The ideal ratio for the number of samples and the sampling rate is 1:1.
2.what filter must be used to make a good ecg signal?
The recorded ECG signal normally containing noise and artifact,usually movement artifacts.So, before we can extract the useful information,we have to remove the noise. There are 2 common noise;baseline wondering and wideband noise. The baseline wondering can be eliminated using 2 approached. Digital filter and using wavelet transform. The wideband noise can be remove using wavelet . Further and details information about this filter can be obtained from this link;
http://zone.ni.com/devzone/cda/tut/p/id/6349
4.how to save result of ecg signal to JPEG or files or coordinate system.
The result of this analysis can be stored to JPEG or other files using report generation pallete. Here I attached you a simple programming to save the ecg signal required from the measurement file .The sample ECG data stored in lvm file. We can choose which type of report we want to generate.
Hope all this can help you a lot.
