08-24-2007 08:16 AM
08-24-2007 08:47 AM - edited 08-24-2007 08:47 AM
Message Edited by Jochen on 08-24-2007 03:52 PM
08-27-2007 04:26 AM
Thanks. I was on the wrong track with the pci-6220.
I just installed the virtual motion drivers and the motion assistant. It looks quite simple just put in a find home, reset counters and ad my steps and wait positions . I noticed I can put the wait stage with a timer or a keystroke this is very promissing.
I have two other question. I'm reading the manual but just to be sure.
First. Can I connect the end switches, just an on/of switch without any other electronics to the pci-7332 motion control ?
Second. The microstep driver has it's own power suply what leaves me with the 3 signals + and - from the pul, direction and enable can i connect thes also without any other hardware to the motion control card ?
This is my microstepdriver
http://www.stappenmotor.nl/Datasheets/microstapdrivers%20info/MSD-50-5.pdf
08-27-2007 04:37 AM
08-27-2007 06:42 AM
08-27-2007 06:47 AM
08-27-2007 07:04 AM
08-27-2007 07:31 AM
That's good to hear, a ne pc was not on the budget list.
Thanks for al the tips and advice.
I will set the limit's as normally closed than.
So l go ahead and start the order for a New PCI 7332 motion controller.
Gr Sjoerd
08-27-2007 08:22 AM
09-03-2007 07:36 AM
