Hi, does anyone know if LabVIEW can work with Agilent Signal Studio Toolkit?
Here some signal have to be generated by this signal studio toolkit instead of signal generator, if using LabVIEW to automate the data processing and test, is there any API or driver available for this? I found Agilent Signal Studio (N7615B) has API based on .NET programming environment, not sure if it's possible to create the DLL files to make them work together.
Thanks a lot,
Jeanne
