I've tried some method, no one works, so I may suggest two work around here
1. arrange the tabs according to the text length, you can arrange the tabs in more than one rows
2. If you have to have the text on the tabs in multi-rows, I think you can prepare a picture with your text in multi-rows, and insert it into the tabs
I hope it may be helpful.
NIhuyu wrote:I've tried some method, no one works, so I may suggest two work around here
Message Edited by NIhuyu on 01-29-2010 01:01 AM
Option 2 might be better. After all, having a "looooong" page label is not recommended since it's an enum and it will be that "looooong" if a constant of it is created 😉
Keep the labels simple!
