How do I access the asynchronous reset mode of Pulnix TM-6710 Camera using PCI 1422. Selecting the Async mode and fast reset in MAX, ALWAYS times out the HL triggered snap example vi.(this example also times out 5%of the time in manual shutter mode as well) I am supplying the Pulnix spec'd negative TTL pulse to pin 6 of the 12 pin connector on the camera, and have investigated various offset times with respect to the trigger pulse supplied to the 1422. I am running IMAQ 2.5.2 and LabVIEW 6.1 under windows 2000.
The following webpage has some information with regards to the Pulnix 6710 digital camera. - http://sine.ni.com/apps/we/nipc.product?pid=1144
According to the support file (Pulnix TM-6710 Support File.txt), the serial communication requires special consideration (since it is not bundled in the standard Pulnix cable). - See the support file for additional information.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site.
Please go here for information on ni.comâ s copyright infringement policy.
