05-27-2010 04:00 AM
05-27-2010 04:18 AM
Hi Oliver,
I can not answer your question (no experience in XML programming). The reason of this reply then is just the comment that we use a slightly different approach for controlling a S7-200 SPS, using a Siemens OPC server.
05-27-2010 05:01 AM
The general question is if CVIXMLLoadDocument is OPCXML DA 1.0 compatibel?
Greetings
Oliver
05-27-2010 05:15 AM
in the CVI examples XMLSample and xmlTree the command CVIXMLLoadDocument is used, may be is gives you some idea?
(PS to my former note: the software we use is PC Access)
