05-19-2009 03:30 PM - edited 05-19-2009 03:31 PM
DEppAtNGC wrote:
I'd prefer something simpler... like a enum that could have colors associated with enum values...
What makes you think that's simpler? It won't be simple because there is no native support for it. 😉 You need to code your way around it.
Some more possibilities:
06-14-2009 10:48 PM
I tried to customize the control as described in post #16, but I always get a square peg and a round hole.
Does this still work?
The help files don't seem to include the possibility of changing shapes....
I'm using version 8.6.
06-14-2009 11:55 PM - edited 06-14-2009 11:58 PM
skierrex wrote:Does this still work?
Yes, of course it still works. The description is only for the central part. You might want to repeat the same steps with the shaded frame too.
Here's what I just did in about a minute in 8.6:
06-15-2009 10:59 AM
Thanks!
I think I get it now.
I have to copy the outer frame, save that, and then I can copy the colored indicator part.
06-15-2009 11:21 AM
Wouldn't it be nice if the enum indicator had native support for a color assignment to each enum value? Those could be set statically via properties or dynamically property node. Wouldn't it be... niice...
06-15-2009 11:36 AM
DEppAtNGC wrote:Wouldn't it be nice if the enum indicator had native support for a color assignment to each enum value? Those could be set statically via properties or dynamically property node. Wouldn't it be... niice...
This is somewhat offtopic here. If you think you have a good new idea, please write it up for the LabVIEW Idea Exchange! 😄
09-17-2009 10:29 AM
Altenbach- you gave a 9 step description of how to do this on Page 2 of this script.
I tried to follow this in order that I might learn more, but keep falling over.
step 3 - What is the wrench? (is it the drop down menu, if so it is greyed out for me)
step 7 - I can only import pictures from an existing file.
Do I need to save the image to a file in the middle?
(LabVIEW 8.6.1)
Cheers for any help. I'm swatting on timesaving techniques and learning how to make things like this from scratch quickly before I start my practise for the CLD exam in the hope that I'll pick up something that'll carry through into the exam.
09-17-2009 10:53 AM
A picture ring with text comes close but you can't change the colors at run time.
Ben
09-17-2009 11:07 AM
James W wrote:step 3 - What is the wrench? (is it the drop down menu, if so it is greyed out for me)
step 3: the wrench is the button in the upper left. If you hover over it, it says "go to customize mode". Once you press it, the wrench turns into forceps.
step 7: typically, you import directly from the clipboard. It should still be there from step #4.
09-18-2009 03:37 AM
Thanks Altenbach.
Next Question - How do you deal with the scaling issue?
When I make my colour box LED and make it smaller, the LED and shrinks faster than the Decal, and when it grows, the LED can obscure the Decal. - I don't undertand this.
