Get inside the Read Key.vi. There you will find Get Key.vi. Get inside this vi. It has two outputs (excluding some others) - value and comment. But the vi itself returns only the value and the comment is left unused. Please check if that "comment" output is the "explanations" you need. If so, you could manually wire that output for your benefit.
Remember to save the vi with a different name if you will edit it.
Message Edited by Giedrius.S on 02-11-2010 10:02 PM
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that...
🙂Chart zoom with "Mouse Over" effect
