06-19-2009 08:06 AM
I have a device which gives 4-20mA AC output and 4-20mA AC input. I have 6036E with voltage to current converter for input and i am reading output directly from the DAQ card.
My requirement is to draw frequency response (bode Diagram) for my device.
Please let me know how to go with this.
Thanks in advance.
06-19-2009 08:22 AM
If you only need amplitude it is very simple. On the input side you apply a know AC excitation. Then you measure the output. Calculate
20*log (output/input). Repeat this for the frequencies you are interested in
06-19-2009 08:59 AM
i dont know this card will support AC signal.. 😞
and i need both amplitude and phase plot..
if u have any examples it would be very helpful.
thanks
06-19-2009 09:11 AM
06-19-2009 11:12 AM
0 to 20 Hz... Please let me know if i have to use any extra hardware for this..
Thank you.
06-19-2009 11:43 AM
06-19-2009 11:50 AM
06-20-2009 02:40 AM
@ Dennis.. I guess i can directly read the current output from the device using 6036E..
@coq rouge.. I have PCMCIA version.. But the problem is i don have analog out from the device..
i know my question is not at all related to labview, but if u have any ideas it would be very helpful.
Thanks..
06-20-2009 05:38 AM - edited 06-20-2009 05:39 AM
If you do not have access to the analog out, for some reason like it is out of order. You have to apply the reference signal with a signal generator or something like it. You can still compare the output/input relation by sampling both the input and output current. But one thing is important. Your DAQ device do not have simultaneous sampling. So a very small constant phase will appear between the two channels
06-20-2009 06:03 AM
