02-13-2009 01:55 PM
02-13-2009 02:15 PM - edited 02-13-2009 02:22 PM
I can confirm that crash in LV 8.6.
The issue appears to be realted to the in-placeness algorithm being a little over-zelous. A work-around is to use the "always copy" node to give the in-placeness algorithm a hint that it is OK to copy the forked wire. see image.
Thank you for reporting this bug!
Ben
02-13-2009 03:26 PM - edited 02-13-2009 03:27 PM
Sure thing.....
And I knew this was a memory thing, I didn't know about the "always copy" vi. I guess I learned a thing or two today.
02-16-2009 10:30 AM
Hi all,
Just wanted to let you know that I have confirmed this behavior in LabVIEW 8.6.1 and reported this bug to R&D. For your records, this bug was filed as CAR#146503. You can use the number to check future LabVIEW release documentation to see if the bug has been fixed. Thanks so much for reporting this bug, monzue. Thanks to Ben as well for finding a workaround!
