01-17-2009 07:51 PM
Hello everybody,
I'm building a CVI application. I need some functions of LabView (related to time series analysis), so I'm trying to build DLLs with the .VIs I need. I followed all the steps necesary and visited all the related topics at ni.com. I always get the following error:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. +¡
Use the following information as a reference: Error -2147221480 occurred at Building DLL stub.
This can be caused by illegal function or parameter names. Please verify your names are legal C identifiers and do not conflict with LabVIEW headers
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
Once, I got a correct DLL with no errors, so it should be possible for others.
This is an example of what I'm trying to compile:
And this is what appears, only for a moment, at the end of the compiling (it didn't appear when I manage to build with no errors):
I'm using: LabView 8.2, LabWindows CVI 8.5, NI-DAQ 8.5, Windows XP (SP2)
Any suggestion is really appreciated.
Maybe another way to use this functions in CVI (I need functions related to spectral estimation, ARMA; MUSIC,...)
thank you!
Eduardo Tamargo
Spain
01-17-2009 09:55 PM
I realized that the problem is when compiling a .vi that receives an array and it's length, because when it receives all clusters, it's builded correctly.
Any suggestions?
01-19-2009 02:39 AM
01-19-2009 04:35 AM
Thank you very much for your reply.
As I could see trying different solutions, the problem is not about the returning value. It seems like the .VIs I wanted to create, are only valid for clusters as input parameters, and not for arrays, despite it offers this option when designing the prototype.
01-26-2009 10:22 AM
Hi Tamargo,
The following KnowledgeBases may help you find out what is happening:
Creating and Calling LabVIEW DLLs with Various Data Types from Microsoft Visual C++
What are the Differences Between "Array Data Pointer", "Array Handle", and "Array Handle Pointer"?
Calling a LabVIEW DLL from C with an Array in a Cluster as a Parameter
Have you tried developing a very simple VI with an array as an input parameter and checking if the same problem takes place when you build the DLL?
01-27-2009 06:13 AM
Thank you for your reply.
By the moment, I tried what I wanted in another computer and it worked, so I think it's related to the NI products intalled in my PC. I've installed several versions of LabView and LabWindows, and at the end, it seems to be a mess when they have to communicate to each other. In a computer with just the whole pack of LabWindows and LabView, I don't get that error. So, I will make the DLLs I need in that computer.
Eduardo Tamargo
