10-30-2008 12:54 PM - edited 10-30-2008 12:56 PM
Is it possible to use VI Analyzer to detect and report if a specific sub-VI (identified by path name) is used within an analyzed VI?
I am upgrading from LabVIEW 7.0 to 8.6. I need to identify the use of specific VIs and replace them with new LabVIEW native functions.
I could delete these sub-VIs and look for broken VIs, but they happen to be part of LabVIEW's 'vi.lib\' hierarchy, and I would rather not edit or delete them.
Solved! Go to Solution.
10-30-2008 02:56 PM
Hi Philip,
I've attached a VI Analyzer test below that should do what you want. In addition to looking for static subVI calls, it also checks string controls/constants and path controls/constants for the VI name you specify, in the event that you have dynamic calls. To use this test in LabVIEW 8.6 do the following:
Let me know if you have any questions or problems.
-D
10-30-2008 03:24 PM
If I could give you 10 kudos right now, I would! This is PERFECT!
Thank you so much!
