09-13-2007 10:42 PM
09-14-2007 01:49 AM
09-14-2007 02:40 PM
09-14-2007 03:17 PM
09-14-2007 03:22 PM
09-14-2007 03:43 PM
Its not a matter of monitor resolution. It's a matter that you've made the block diagram much too large and difficult to view.
You have some basic misconceptions about how LabVIEW works. You are confused why one part updates the same line. In this code, you are creating a brand new array each time. If you want to append new data to the old, use a shift register and the Build Array function.
If you are getting two lines with the same time, then the table is being updated more than once a second.
The Export to Waveform Function does not appear correct in Excel when you use an .xls extension because you are using the incorrect delimiter. Your delimiter is two spaces. Excel assumes a tab. If you had just left the input unwired, it would have worked.
You also need to clean up the style of wiring. The convention is data flows from left to right and in some places you have wires going from right to left. Also try to keep wires straight where possible. Having wires that look like staircases does not enhance readability.
09-14-2007 04:06 PM
@Mrjazzitup wrote:
I think if you go to VI properties then go under Windows Size and uncheck the "Maintain proportions of window for different monitor resolutions" you can get it to work.
09-14-2007 04:11 PM
09-14-2007 04:26 PM
09-14-2007 04:33 PM
