Can't find merge dialog in Labview 8.5
I just installed Laview 8.5. I want to use the merge tool but can't find it anywhere. Everywhere it says it is under Tools Menu but I can't see it. Can anybody help me with that? I can find the LVMerge.exe for use with SCCS.
thanks
vik
Message 1 of 8
(3,680 Views)
It is under the Tools menu as shown in the attached image.
Which type of package do you have?  Base, Full, Professional, Developer Suite?  I'll check if it's with all versions...
Message Edited by JoeLabView on 09-12-2007 09:57 PM
Message 2 of 8
(3,664 Views)
I looked around to see which package supports the feature...  There was no mention about package specific that I could find.. I'll continue looking.
Message 3 of 8
(3,661 Views)
hey,
        Thanks for looking around. I have installed Labview from the Full Development Suite but not sure whether that really matters. I have attached a screen shot of tools here. It is different than yours.
Bhavik
404-978-8034
Message 4 of 8
(3,633 Views)
Here's my Tools menu which is a liitle different than Joe's but the Merge VIs is there. I notice that you also don't have the Compare option. I know that this is only available with the pro version of LabVIEW so maybe the Merge is only part of that package as well.
Message Edited by Dennis Knutson on 09-13-2007 09:03 AM
Message 5 of 8
(3,629 Views)
Can somebody tell if "Merge VIs" is only available in the Pro version?
I have installed Labview 8.5 Full version and I also don't have the merge option in the tools menu. NI does not mention on the website and manuals that you need a specific version.
I have found LVmerge.exe on my computer ("D:\Program Files\National Instruments\Shared\LabVIEW Merge\LVmerge.exe") but it is not possible to run it because you will get an error (= code 1: Invalid arguments passed to application.).
Thanks in advance,
BJK
Message 6 of 8
(3,446 Views)
If you go here and click on the 'software Engineering Tools" that is listed as being available only for the pro version, you get what is show below.
Message Edited by Dennis Knutson on 02-20-2008 07:32 AM
Message 7 of 8
(3,434 Views)
Hi Dennis,
Thank you!  It's clear now!
BJK
Message 8 of 8
(3,428 Views)
