06-12-2007 02:08 PM
06-13-2007 04:47 PM
06-13-2007 04:54 PM
06-13-2007 05:01 PM
The workaround worked great Stephen! Thanks to both Nadim and Stephen for your quick responses.
I will keep one eye open for the LabView update that will address this.
Steve
06-02-2009 01:36 PM
Stephen,
Has the problem with the property nodes in VIs with web publishing tool been solved?
I am using LabVIEW 8.6 and still seeing the same problem.
Archana
06-03-2009 04:10 PM
Hello Archana,
I looked up the Corrective Action Request described by the Applications Engineer in the previous posts and this is not a bug.
It is a bad idea to use vi server to interact with front panel controls
if the vi will be viewed over remote panels. The vi server properties
are trying to access the controls on the panel in the browser that was
just closed. The error is a valid error condition and should be
reported.
The solution, as mentioned in the workaround, is to handle the legitimate error so the default dialog isn't popped-up.
Hope this helps,
06-09-2011 09:35 AM
Hi everyone,
concerning this topic, does anyone know how to get into the vi on the host machine a kind of signal when the client web browser (controlling the remote panel) is closing?
I just want to use that signal in order to shut down the circuit controlled through the vi to prevent a damage of the system.
Thanks in advance.
Alessio
06-10-2011 05:12 PM
Hello Alessio,
Is this for a user-controlled web browser closing or for a situation where it closes on it's own, where we want a safeguard? There is a Wait for Front Panel Activity Function and a Remote Panel:Client Connections Method that may be useful to transfer the information necessary to then signal a case structure to shut down the circuit.
Thank you,
Deborah Y.
06-17-2011 08:50 AM
Hi Deborah,
the remote panel client connection method was exactly what I needed!
Thanks a lot,
Alessio
03-14-2014 06:36 AM
Hello all,
sorry for reanimating such an old thread.
I am still hitting this error in LabVIEW 2013. My application is quite big, that's why I have to use Property Nodes in Sub VIs to change Front Panel Elements in my upper VI (I read about this method somewhere in the forums and if I remember correctly, it's the recommend way for such a case).
Also, I can't just clear the error of the Property Nodes, because my Remote Front Panel will just stop refreshing, as the error will occur every time the Property Node is called.
I'm not opening the Front Panel via Browser, just pure LabVIEW.
Attached is a minimal non-working example. I am using LabVIEW 2013 SP1 32 Bit on Windows 7 SP1 x64.
Steps to reproduce:
- Open and run the Main VI on the Local Server.
- Connect to the Server from the Remote Client with "Request Control" enabled.
- Release control on the remote side or just close the remote window.
Main VI:
Sub VI:
Much thanks in advance,
Clement
