Hi Dima,
It appears that some of your project's properties may be causing this problem. Since O2 optimization appears to be incompatible with RTC1, you may want to verify this setting and try disabling it if it is enabled. To do this, Go to your Project -> Properties (For Debug Configuration):
Configuration Properties -> C/C++ -> Optimization" tab, set the value of "Optimization" to "Disable (/Od)"
For some additional information on this error you may take a look at:
http://msdn2.microsoft.com/en-us/library/t0cs92zx.aspx
I hope this helps. Have a great day!
Steven C
