In LV 8.x, the "Value Change" event for a Color Box is firing twice. Run the attached VI and select a different colour - you should see two points on the chart. Interestingly, writing to the "Value (Signaling)" property only causes the event to fire once. I'm guessing this bug was perhaps introduced when the weird window switching caused by the colour selector in LV 7 was fixed?
Jaegen
