07-10-2006 02:10 PM
07-10-2006 02:22 PM
07-10-2006 04:37 PM
07-11-2006 08:08 AM
Thanks Darren,
I had a feeling it was simple. Using a Worksheet property node tied to a Page setup property node with Right Footer displayed, I connected the code you suggested (Page &P of &N) from a text box to the Right Footer. Works like a charm thru hundreds of pages!
Nick S
07-11-2006 11:19 AM
Joe,
Heres some code. Yell if the zip file does't make it. Place the two files on the C:\ directory.
07-11-2006 01:14 PM
07-12-2006 04:27 PM
Joe,
You seem to know your way around the Dev. Zone discussion format.
How did my question get removed from the main board? I thought I'd have to do it myself.
Instead I found that it is only listed in My Subscriptions. What did I miss? What should I normally do to it? Delete it or just leave it alone.
07-12-2006 05:57 PM
It did not get removed it just got pushed way down the list. When you ask a question it gets put on page 1 of the main board. and as more people ask questions it gets pushed down the list (very quickly) then when some replies to your question it gets put back at the top of the list. Lather rinse repeat. you can verfiy this if you want. Down at the bottom of the main page is an indicator to tell you what page of the main LV page you are on. A question just keeps getting pushed down the pages.
You cannot delete a Post. Only the board administrator can do that.
Hope this helps.
02-11-2011 02:27 PM
LabVIEW Report Generation Toolkit for Microsoft Office
This is a dead link.
