06-23-2006 07:43 AM
06-23-2006 07:59 AM
06-23-2006 08:26 AM
Sorry there was a mild accident. I resubmitted. However, the code is now attached.
Morris W.
06-23-2006 08:58 AM
06-23-2006 09:27 AM
Hello smercurio...
Your suggestion of how to drag the control reference from the Main.vi to the WLp2.vi is how I created the references initially. I then created a .ctl file for it, I guess this is not something you would do. Will you tell me how you would go about passing the controls to the subVIs within a cluster and then in some method edit only one cluster, I thought through a strict typed .ctl file, so that all clusters are edited at the same time.
In this example I would like to edit the cluster in Main.vi and then that cluster be updated automatically within the two subVI’s, WLp1 and WLp2. Perhaps one could add another control to the cluster in Main.vi and then appropriately edit WLp1.vi to use the control, while WLp2 that does not use the control is automatically updated.
Thanks for the help,
Morris W.
06-23-2006 09:40 AM
06-23-2006 10:29 AM
06-23-2006 11:30 AM
