06-21-2006 01:42 PM
06-21-2006 01:54 PM
06-21-2006 01:55 PM
06-21-2006 02:09 PM
I do not think I could post any code as it would be against my companies policies. For an example, I just heard on department in this company took the time to recode all their tests as queued state machine. There are very few reason to code tests as state machines. The flow is: set switch path -> set instruments -> set UUT -> Make readings ->determine pass fail. Any repeat on failure can be accomplished with a while loop. I am new to this company and I know I have a battle on my hands trying to eliminate the one vi does everything coding. I believe in function blocks that lend themselves to code reuse. I am actually in a group that used stacked sequence structures(reading this is my real frustration) for everything and now wants to move to the message handler structure. I guess I'll have some good debates in the weekly meeting.
06-21-2006 02:13 PM
06-21-2006 02:41 PM
06-21-2006 02:42 PM
06-21-2006 06:12 PM
What's up with queued state machines these days?
Half the afternoon, the guy next to my cube was complaining at how "whoever implemented the queued state machines did a bad job"... And the program is in C++ !!!! 😮 !!! 😮
And now I read this thread... It seems like it's the new trend..
Why?? Did I miss some sort of "DaVinci's SW Code: Using queued state machine " ???
Yikes
06-22-2006 01:06 AM
06-22-2006 01:48 AM
Epictetus
