04-11-2006 04:42 PM - edited 04-11-2006 04:42 PM
Message Edited by GHernandez on 04-11-2006 04:43 PM
04-13-2006 04:37 PM
04-13-2006 05:22 PM
04-18-2006 04:36 PM
04-19-2006 01:42 PM
04-19-2006 02:16 PM
04-19-2006 02:42 PM
I don't think you can wire this device to an analog input. It has four pins. VDD, GND, DATA, SCK
The SCK is used to synchronize the communication between a microcontroller and the SHTxx. Since the interface consists of fully static logic there is no minimum SCK frequency.
The DATA tristate pin is used to transfer data in and out of the device. DATA
changes after the falling edge and is valid on the rising edge of the serial clock SCK. During transmission the DATA line must remain stable while SCK is high. To avoid signal contention the microcontroller should only drive DATA low. An external pull-up resistor (e.g. 10 kΩ ) is required to pull the signal high. (See Figure 2) Pull-up resistors are often included in I/O circuits of microcontrollers.See Table 5 for detailed IO characteristics.
04-19-2006 03:45 PM
04-20-2006 07:08 AM
here http://forums.ni.com/ni/board/message?board.id=170&message.id=137823#M137823
wha@atmel post a llb for the printerport that talks to an AD??? device, maybe that code gives you an idea...
06-13-2006 06:16 AM
