recovery of the DLL dynamically by the software labview
I have a spectrometer mobile.It allows to recover valeurs.It is composed of a spectrometer and a Central processing unit to record the data. The goal is to be able via a portable computer connected by usb has the central processing unit to recover these data when one needs some. I must in makes recover the DLL of the spectrometre then to control them by labview.Alors as I know nothing there (debutant), I will like to have a little assistance, the examples... to understand how to make.
thank you.I'm french
(2,847 Views)
Hi clodinho,
you need to have the appropriate driver if you are using Non-NI-Hardware.
You can search for already implemented Drivers here:
Instrument Driver Network
If you can't find an appropriate Driver, have a look at this.
Using NI-VISA 3.0 to Control Your USB Device
If you are using LabView 8.0 you can find example VIs with the Example Search Engine and search key "Agilent 34401"
 Andi
~~~ Logic is a systematic method of coming to the wrong conclusion with confidence ~~~
(2,820 Views)
