03-09-2006 03:00 PM
03-09-2006 04:23 PM
Can we turn your statement around and assume that the possibility of crosslinking is zero for people like me who don't store anything personal in the LabVIEW folders? Is this correct?
@Jeff B wrote:
If you do this, however, please understand the slight risk of VIs of the same name getting cross-linked in your distribution, particularly if you have saved anything under the LabVIEW directory.
03-10-2006 03:43 AM
As long as you do not have any modification to VIs inside the LabVIEW folder AND of course only for compiling VIs inside the LabVIEW folder ;-)
@altenbach wrote:Thanks Jeff,
03-10-2006 11:46 AM
Hello altenbach,
Unfortunately, no, I can't say that. We did most of our internal 8.0.1 testing with no cache during mass compile. This is really a very complicated issue to address, as aside from LabVIEW, there are modules, toolkits, drivers, not to mention any possible 3rd-party toolkits / drivers any customer could have installed. Even without 3rd-party files involved, I can make no promises here.
What I can tell you is the following:
"The VI expected to be at "[path referenced by caller]" was loaded from "[found path]"."
So at the least, you can tell that it happened, and go fix the issue in the event it did. Hope this helps!
03-10-2006 01:42 PM
One correction here. I think it will work for most LabVIEW Toolkits but there seem to be issues with the LabVIEW FPGA (and probably LabVIEW embedded but I didn't try that in 😎 with cross linkage of VIs. Not sure if it is just a cosmetic error or if it will definitely cause serious problems but I got several cross linking messages in the mass compile log for the FPGA related VIs.
@rolfk wrote:
As long as you do not have any modification to VIs inside the LabVIEW folder AND of course only for compiling VIs inside the LabVIEW folder 😉
