12-06-2005 03:03 PM
12-07-2005 10:48 AM
Update: now I only have the symptom. I took a cue from the insane object messages and deleted my only waveform chart--which had been in the code, unchanged, for years! Now I can edit and save without error. However, the control cluster still does not carry the cluster changes when connected to the subVI--but it DOES when connected to only the loop border!!! So there's nothing wrong with the cluster itself. The only thing I can think of to do is recreate the subVI the cluster connects to.
Does anyone have any other ideas or experience. I've been programming in LabVIEW for over 15 years and I have never seen anything like this before!
12-07-2005 11:26 AM
12-07-2005 11:41 AM
Thanks for the response, tst. The subVI in question is about 290k, but I want to try copying the block diagram to a fresh VI before posting it. However, I did recreate the cluster control in a fresh VI, and copied it to the VI and the subVI--in that process I did disconnect and reconnect to connector pane.
Yes, you are right about the red error terminals. But, in my case, this happened as a result of automatic code conversion from an earlier LabVIEW version (by default, such conversion sets the node to ignore errors within the node).
I'll update this thread with the results of my attempted recreation of the subVI. Thanks, again, tst.
12-07-2005 11:44 AM
Yes please post an example or summarize your solution.
I have seen issues with "circular references" like Property node >>> Value wired to bundle by name, wired to indicator getting confused.
That is the only thing that comes to mind.
Ben
12-07-2005 12:14 PM
Thanks for the response, Ben. Your "circular references" comment is interesting...not sure why you say "circular", but at one time I did have a different input of the subVI wired to a bundle (not by name) of arrays read from property nodes associated with 4 of the boolean controls in the control cluster. I was having trouble before I removed this input--but I may not have removed the terminal's control within the subVI. Still, though, the corresponding indicator is being unbundled (not by name) outside the subVI, and the unbundled arrays being written to string[4] property nodes associated with the same 4 boolean controls within the control cluster. So, what was the "confusion" you mentioned?
12-07-2005 12:26 PM
When I first heard an explanation of what an "Insane Object" error was, I understood it as an indication that LV was not able to propely account for something in the code. When I said "confused" I was thinkning of how I understand the "Insane Object" error.
Ben
12-07-2005 12:48 PM
I just had an insane object problem with LV for the first time ever yesterday.... so it's funny that this post is up now.
I found that my specific 'Insane object' was some VI server stuff that wasn't properly linked. That being, I had a couple instances where I had copied and pasted the invoke node and property node VI server objects from one location to another. However, I found out that when I copied these, the links defaulted to no-link. A simple fix, I just clicked on the nodes and re-linked them to the proper object and all insanity was averted.
So yeah, try checking to make sure all of your nodes are properly linked!
Though, it's probably not that simple... nothing ever is.
Jonathan
12-07-2005 12:52 PM
Ben, I did manage to get rid of the insane object errors, as near as I can figure, by deleting the waveform chart cited in the insane object error messages. That chart has been in the code for years, and during that time the chart, which charts a scaler integer representing the number of milliseconds it takes for the main loop to iterate, would show a gradually increasing value. When first started, it would show a flat line at about 50 ms (not bad, given a 25 ms wait in the main loop). After a week of running I'd see spikes on the chart up to 200 ms; another week and we're up to 500 ms. This level of delay begins to create problems. I found that exiting and reentering this VI (this VI is itself a subVI of the larger app--about 420 VIs) would "reset" the chart! Then I found that if I just skipped one "conversation" with the chamber controller (GPIB, at 3-sec intervals) the chart would reset, without my having to exit and reenter. I still don't know what the problem was, but my "remedy" was to programmatically skip one conversation every 20 hrs. I also revamped the chamber communication VI for efficiency sake and to eliminate the 488.2 GPIB functions (there are a number of reasons why we must decline to use VISA), which the chamber controller was too old for (somebody else had written the chamber comm VI). The changes worked great--I thought I was golden. Then this apparently unrelated (I'm not so sure that anything in LabVIEW is UNrelated to everything else) issue cropped up.
If there's anything in the above that jumps out at you as a possible problem, please let me know. Thanks again, Ben.
12-07-2005 01:04 PM
Thanks for the response, Jonathan. It's interesting that you mention VI server. One of the latest additions that I made to this code was a little plug-in architecture thing, but I never copied and pasted any of that, and it all worked as expected and hasn't been touched since.
I haven't tried yet to reintroduce the offending waveform chart, the deletion of which seemed to restore sanity to my code. When everything else is working, I will do that . I just don't see how this chart could have become a problem...
