08-04-2005 07:36 AM
08-04-2005 08:50 AM
Saving the combobox as a strict typedef will fix this I think, although will limit you if you want the comboboxes to look different in each instance that it is used.
Paul
08-04-2005 08:52 AM
Saving as a strict type def does not work, it looks like a LV bug.
08-04-2005 08:59 AM
Interesting, If you place an indicator or control linked to this combo-box strict typedef, it works but not with a constant on the diagram. Now if you convert the constant to an indicator and then back to a combo-box, it is updated? Guess this is a bug unless there is some reason for not implementing this? I have used typedef enums many times and this is not a problem, I don't understand the difference. Sorry
Paul
08-04-2005 09:02 AM
08-05-2005 04:32 PM
I was able to reproduce this in 7.1.1. I will report it to our R&D department. I noticed the exact same behavior...if you flip to a control and then back to a constant it updates.
-Brett Burger
Applications Engineer
01-22-2007 04:29 PM
01-23-2007 01:08 PM
01-23-2007 04:00 PM
01-24-2007 01:07 PM
