I have a LV2 global on steriods that has to store data that I am collecting from 448 channels at 1000Hz.
When I attempt to use a "initialize array" to create a 448 X 90,000 array of I32's (this will be my buffer) LV crashes saying it does not have enough memory to complete this operation.
If I back down the "90,000" to "80,000" it appears OK and the Task manager >>> Performance tab indicates that I am using about 0.97 Gig of memory.
Bump it back up to 90,000 and crash!
I have 4 Gig in this machine so This should work.
So...
has anyone else seen this issue?
I am going to chase down DF Gray presentation because there may have been something in there I over-looked.
In the meanwhile, if you can help out, I would appreciate it.
Ben
Now where did I see that presentation?
