Return Status BFFF003E with visa serial write
Visa says connection ok but gives a return status of BFFF003E and will not return OK after AT command
(4,591 Views)
Do you have handshake enabled or is the serial connection sending CTS?
(4,586 Views)
I got this error with a USB serial port. I solved this using the buffer function for this serial connection.
(4,578 Views)
This KB could be helpful.
Peter Flores
Applications Engineer
(4,556 Views)
