10-15-2008 09:48 AM - edited 10-15-2008 09:52 AM
The NI Discussion Forums has a new feature, the ability to mark a particular reply as the solution to your question!
Marking a solution allows other users to quickly and easily:
When you mark a reply as a solution to your question, the thread is marked as "Solved" () and you can click on the "Go to Solution" icon to jump directly to the accepted solution:
Best practices:
I hope that you find this new feature useful!
Laura
Web Support & Operations
10-16-2008 03:18 AM
10-16-2008 06:55 AM
Laura F. wrote:
- If you mark the wrong reply as a solution or a better solution emerges, you can unmark the solution from the Options menu. You can unmark a solution at any time.
In case a beginner starts a thread with a basic question and it was immediately answered and he marks it as solution, but maybe few hours or days later, if another one gave a better solution than this and if as a beginner the owner didn't know which is a perfect solution, then how this situation can be tackled in the forums????
Maybe this can be made flexible, so that the owner of the thread can mark some multiple answers as solutions.
10-16-2008 06:57 AM
Only one solution can be marked per thread.
Remember this quote,
"Like a coin is having two sides, a query can have more than one solution."
10-16-2008 07:04 AM
10-16-2008 09:44 AM
10-17-2008 01:23 AM
11-10-2008 12:10 AM
sir
we are interfacing the accelerometer with with the brick to find the direction using lab view as the software, it gives the speed only in X-direction, but it operate in in all directions X,Y,Z-direction and does not gives us in Y,Z diretion speed
Plz urgent reply
waqarshl@gmail.com
11-10-2008 12:20 AM
i m interfacing Accelerometer with NXT Brick using LabVIEW and i have used Ultrasonic sensor block for interfacing
but it will give us the values in only X-direction but we need it in Y and Z-axis values also . rply urgent
11-10-2008 12:45 AM
* Waqar:
You posted in the wrong forum and in the wrong thread for some unknown reason. Do you have problems with the online interface?
Try to post in the NXT forum for better results. Good luck.
